Port'a'build: Vitruvian (Now 10x more likely to flood!)
AstroDogs
Date sent: 2016/08/11 09:19:32
Not sure what exactly the coords for the Vitruvian are, but the warp for it is warp Vitruvian. Since Luigi is hopefully bringing over builds soon, I was hoping that he or anyone else with op with the ability to port over builds, could bring it to the seafloor at X : -3241 Y: 31 Z: 1650. I know this is kind of a pointless location, as it'd be easier to put it on the surface, but an underwater Vitruvian is Fiji water level aesthetic.
Also to be more specific : Only the main building (The large + shaped building with the dome in the center), the majority of surrounding buildings are either incomplete, or unwanted at this point in time.
Date sent: 2016/08/11 09:22:35
What do You mean by this post? Are you asking to get a build transferred?
AstroDogs
Date sent: 2016/08/11 09:25:22
Yeup. Gilgamesh did it, and Luigi responded, so I thought why not. :P
Date sent: 2016/08/11 09:50:20
Ah, ok.
AstroDogs
Date sent: 2016/08/12 08:45:55
Bump because I need my daddy Luigi to potentially port this ( ͡°ᨎ ͡°)
Date sent: 2016/08/12 11:40:55
Transferring a build from the surface to underwater will remove the water blocks and replace them with air, so I can't really transfer it to be fully underwater.
Date sent: 2016/08/12 14:44:10
Luigi you can then use the world edit command that fixes water. I forgot the name but it makes water where there should be
AstroDogs
Date sent: 2016/08/12 19:36:28
Luigi I'd be fine with that. I have the resources to recover it if it doesn't have water there. Buckets and water can go a long way, am I right?
By what I mean, Ive quickly made a doodle of what I mean.
http://imgur.com/a/JlsyX
Have it in the ocean, far enough down where the entire dome is covered, and then on the surface, build over it with dirt, use buckets to cover that dirt in water, and remove all of the dirt. Resulting in the build being reclaimed by the ocean. (I hope this makes sense..?)
Date sent: 2016/08/13 04:02:22
The water blocks that flow onto it won't be source blocks though, they will be flowing downwards, making it virtually impossible to swim up to the surface.
AstroDogs
Date sent: 2016/08/13 04:10:21
That's perfectly fine for me. I'd just really enjoy having the Vitruvian on the ocean floor near Rapture. No matter if you can, or cannot swim up, as long as its there, it'll be fine, for me at least.
AstroDogs
Date sent: 2016/08/13 21:41:18
Disregard this response.
