Forum Index > General > Build Transfers > Read the topic
Build Transfers
Date sent: 2018/08/01 02:03:22
Build Transfers are now available.
As we all know, the map reset was a short while ago and has upset some people regarding lost builds. However, we have been working on a means to do transfers. We WERE going to use the old multiworld plugin, meaning you could switch between worlds on the same server, to obtain coordinates, warp names, and whatever else in order to have a build transferred.
However, it seems that plugin wasnt compatible with 1.13, so instead luigi has opened up a temporary second server. The IP is mc2.webbcraft.co.uk
The second server's map is the map from last reset, and everything is the same as you left it. TO JOIN THE SERVER ON THE OLD MAP, YOU MUST BE ON 1.12.2
In order to get a build transferred, it must follow a few rules.
One: no items! No items from the last map may be transferred. Some items may be transferred, such as the books in Gilgamesh's library, as they contain server history and offer no advantage ingame when playing survival. If you believe you have an item, particularly books, of similar criteria, feel free to message myself or luigi about it when you request a build transfer.
Two: No large amounts of Valuable blocks, such as diamond or gold blocks, etc etc. These blocks could be mined out to convert back into items in the new world, and used to gain an advantage, which is not allowed, or would be a huge target for griefers and raiders. If your build contains a large amount of these blocks but you want it transferred regardless, destroy these blocks.
After all that, take down the coordinates of the building in the old world, and then give the coordinates in the New world that you wish it to be transferred to.
Message those coordinates along with your transfer request preferrably to luigi, either ingame or on discord, or leave them here on this post. If you MUST message someone about it quickly, you may message me ingame or on discord, and I will forward it to luigi. As soon as I am able to fix World Edit for myself, I will be able to assist luigi with transfers.
Thank you!
Date sent: 2018/08/01 05:34:23
I'd like to add a third rule: the location in the new map should be within 10k blocks of spawn.
This goes for any large-scale projects on the new map as well: don't build them past 10k blocks. There is no world border on the new map and the motivation for this is to allow an unlimited amount of exploration land for players. HOWEVER, the only reason we are able to allow this is because regions exceeding a distance of about 10k to 20k blocks away from spawn will be periodically deleted. This will be more likely the further away it is, and if it hasn't been modified in a while (no one has been there).
Grovemeister
Date sent: 2018/08/01 13:55:32
The Old Multiworld Plugin, has bugs, If You Died In The Old World With Diamonds Your New World Inventory Would Overwrite Your New World Inventory Giving You Diamonds
MaxWreck
Date sent: 2018/08/01 16:06:33
If it's a map art, do you still want it to be in the 10k ? It's not the best thing to visit :P
legomine709
Date sent: 2018/08/01 20:32:36
Ooh transferable builds
MT524
Date sent: 2018/08/02 12:54:10
I'm fairly new to the server and don't know exactly what can be transferred and what cannot, so I'll just put a list of builds here with the coords and description.
Overworld:
Faction house | old coord: -7813 68 3030 | A house mainly built with concrete & glass. Iron farm directly above the house
Various farms | old coord: -7800 64 3078 | Villager potato farm, chorus fruit farm, hostile mob farm, melon & pumpkin farm, manual tree farm, cactus farm, beacon
Villager spawner with trading hall | old coord: -7796 15 2989 | Mainly built with stone
Skeleton & spider spawner | old coord: -7726 17 3139 | -
All the builds above will be at around -9500 64 396 in the new map (if they can be transferred)
Nether:
Blaze farm | old coord: 1579 67 1146 | new coord: -1187 64 49 | Built with concrete and glass
Zombie pigman farm | old coord: -976 256 376 | new coord: -1187 256 49 | A large farm built with stone (half finished)
Again, I am not sure what can be transferred, so sorry if I'm being stupid here :P
Sorry for bad eng
Thanks
XxSotiriSxX
Date sent: 2018/08/03 11:44:24
1) Image
2) Image
3)Image
Date sent: 2018/08/04 00:26:32
Update: Randito and I are now able to transfer builds in addition to Loki and Luigi. Contact any of the 4 of us if you'd like to request and discuss a build transfer!
Date sent: 2018/08/12 06:30:30
Final call for build transfers from the old map!
We have not started putting them into the new map yet, we are still waiting for WorldEdit 1.13 is out. If you want something moved from the old map and havent requested it yet please do so within the next couple of days
legomine709
Date sent: 2018/08/12 20:19:49
I accident commented the letter q
legomine709
Date sent: 2018/08/12 22:15:56
Bad spelling /\ and can't be bothered to edit
fatmanjumprope
Date sent: 2018/08/13 01:36:57
If I got my house transferred, could I bring with it my collection of player heads that are on the walls inside? Some of them are of players who no longer play, and recollecting them would be troublesome.
If possible, here's the coords and a couple pics of the house.
Date sent: 2018/08/13 10:24:01
@legomine If you aren't able to get online, you can post the cords/warp/home to the build on the old map you want transferred, and I can just put it somewhere near your base on the new map.
@fatman You need to include the coordinates where you want it to be on the new map.
legomine709
Date sent: 2018/08/13 10:42:15
I would like /warp tesco to be transfered
fatmanjumprope
Date sent: 2018/08/13 10:49:30
Ah yes, sorry about that!
If you could put it someplace around here, that would be great!
You can do /warp fatshop on the old world to get really close to the house.
Date sent: 2018/08/14 02:03:51
Is it ok to private message a staff member regarding the location on the new map where a build should go. Had a lot of hassle from certain players last time.
Date sent: 2018/08/14 03:59:21
Yeah Belg, You can message me, Randito, Loki or Luigi about it.
legomine709
Date sent: 2018/08/18 10:24:51
can I have /warp tesco tranfered so the front wall is in line with the dirt line at /warp tesco on the new map
