 Mr. Bond
Date sent: 2017/09/23 05:46:07
So since I was told to put the locations of the things I want moved over to the new server, here it goes.
The sky base, which is located at 1498, 57, 4579, however u need to fly up and to the right and you will see it.
The boat at the same location.
The Mall which is located at 1177, 31, 1741.
Few things to note. The sky base main layer needs to be moved over at the same height otherwise the top of the temple will be cut off. And please make sure the underside of it is also moved over correctly, (Not the long pillar thing that leads to the farm, just the basements). The mall needs to also be copied over with everything intact, which includes the mined out area behind the giant statue. The mined out area has a base at the back which isn't ours. Don't copy that over, just right until the door. and also, the mall is all underground, so make sure the floor is on the same level. along with the height of the mall. I would just measure out 10 blocks out from the furthermost point on each side and copy it over so to make sure nothing is left out.
Just please make sure everything is moved over how it is.
Thanks,
Mr. Bond |
