 MagicalMelonSamm
Date sent: 2017/03/11 11:28:43
whenever i join a server minecraft just crashes and i dont know what too do. send help |
 Dragon
Date sent: 2017/03/11 12:13:32
Dunno how to help you there. Try taking note of your servers and backing up survival worlds so you can delete and re-install mc? Has helped me if I have ever had issues. Otherwise idk. |
Date sent: 2017/03/11 13:58:17
Now I'm not sure but I used to have the same problem with my old computer. The way I solved it was getting a new computer (:P) but I think it has something to do with the hard drive or the graphics card. |
Date sent: 2017/03/12 02:17:39
Try going into Options on the main menu and turning your render distance to 16 or below if it's above that. If that doesn't work go into Video Settings in Options and disable VBOs. (This usually happens when you switch your Minecraft version then switch it back) |
 MagicalMelonSamm
Date sent: 2017/03/12 09:24:37
its still crashing D:
 MagicalMelonSamm
Date sent: 2017/03/12 09:51:19
Nope! I have fixed the issue! Thanks for all the support tho guys! |
