WARNING!! 1.11 APPROACHING!!
cptjacksparrow42
Date sent: 2016/09/23 22:44:48
Attention, all players on Mushroom Co.! I am writing to warn you of an upcoming feature which has already made it to the snapshots. There is a new gamerule known as maximumEntityCramming, which is set to 24 by default. This means that if 25 mobs/players occupy the same block, they will begin to suffocate. So, once the server updates, when you go to xp farms such as endermanxp, do not step inside the zone where the mobs will land, as you will get trapped and then suffocate. YOU HAVE BEEN WARNED!! BWAH HA HA HA!!!!
Date sent: 2016/09/24 07:04:50
Hooray! Finally Mojang are adding things to the game that help reduce lag instead of creating more of it.
Date sent: 2016/09/24 10:05:35
By block you mean literally that one block or a chunk? If just that one block this is awesome.
