 MegaMC _
Date sent: 2016/08/10 16:31:45
I've been hearing several rumors about the End resetting. Is this true? I've put many hard hours into building my base, including using redstone. This would basically means I'd be restarting what I've done so far, besides a shop, and a few other decoration only buildings at my f. home. I also know other people who have worked for several hours in the End, like Lammeh, who built the Endermanxp farm. |
Date sent: 2016/08/10 18:45:46
I don't think it is being reset, I've heard nothing but I may be wrong.
Date sent: 2016/08/11 06:19:58
If you build too far out, particularly more than 10,000 blocks away from the origin in the end, then yes it is prone to possible resetting because the world border is set at +/- 10,000 blocks. The closer you build to the origin (0,0) the less likely your build is to be affected by chunk corruption and resetting. In fact, this has always been the case. |
 MegaMC _
Date sent: 2016/08/11 13:46:44
My base is in the area of 7000x4000. Would I be fine? |
