Gavin disrespectful
Date sent: 2016/01/26 20:54:22
Imagehttp://puu.sh/mKJjx/af4864772b.jpg
that is all from me, other people may have other stuff
Date sent: 2016/01/26 20:55:12
derp forgot to mention, he was muted for being disrespectful, then goes and breaks rule 4 (do not abuse) by bypassing that mute
GavinChamp1
Date sent: 2016/01/26 20:56:58
I have the right to bypass if I was muted for no reason.
Date sent: 2016/01/26 21:38:32
No you don't Gavin. you was muted for a reason, a good reason. And even if it wasn't a good reason, you still can't bypass it.
Date sent: 2016/01/26 21:57:35
If you feel as if a mute was unreasonable you may either wait out your time and then ask why you were muted or make a complaint on the forum. Bypassing the mute by using commands such as minecraft:me or using factions etc is a breach of Rule 4.
GavinChamp1
Date sent: 2016/01/26 21:58:29
KGEvans ID pls?
ARNJ
Date sent: 2016/01/27 00:47:49
YOUR ALL IN THE WRONG .........
ARNJ
Date sent: 2016/01/27 01:09:59
Actually nvm DO away with Gavin he's a shot nosed prick. Good job KG
GavinChamp1
Date sent: 2016/01/27 01:30:36
When ARNJ gets roasted so he changes his mind xD
