Forum Index > General > Lerz is hacked. > Read the topic
Lerz is hacked.
larsy13
Date sent: 2016/01/24 18:26:24
Hi folks,
it seems that the account 'Lerz' is hacked. Penquinator decided to temporary ban him until Lerz has his account recovered. Why did she tempban him? Lerz was on the server and may cause trouble if we allow his account to be on the server.
For (the original) Lerz: Please point out you have recovered your account and Penquinator or someone else from the staff will unban you. We got you covered! ;)
Thanks, folks, for reading this news. If you have encountered any trouble, please contact the staff immediately and we will fix it as soon as possible.
Lars signing off
Date sent: 2016/01/24 19:14:40
sorry for wasting your time Larsy, but it was me... i needed to do something but i didnt have the perms on my account... Lerz wasn't tempbanned, idk where you got that info from O.o
Date sent: 2016/01/24 19:53:15
the use of an admin account by a mod shouldnt be granted. luigi hasnt trusted you with admin powers, so you shouldnt be able to access them... just saying this before luigi does. i think luigi will have a word with lerz
larsy13
Date sent: 2016/01/24 20:42:44
Excuse me for my post. I was informed with the fact Lerz was hacked and was later tempbanned.
Date sent: 2016/01/24 21:08:04
What? I wasn't hacked. My personal details are well and safe with me.
Not sure who told you that I was hacked..
Date sent: 2016/01/24 21:17:10
Chip went on your account and said you were hacked.
I kicked your account Lerz.
Date sent: 2016/01/24 21:17:20
Also I agree with KG
Date sent: 2016/01/24 21:30:05
it would be understandable that i shouldn't use an admin's account to do something that my account didn't have access to.
Although, branching from your point KGEvans, "luigi hasnt trusted you with admin powers, so you shouldnt be able to access them." - i think that if there isn't enough trust between Luigi and a staff member for them to have admin perms, then they shouldn't be staff at all, because it shows that there is trust issues there...
i do not believe that staff ranks are based upon only trust, but how well that staff member does their job.
not once have i abused my access to Lerz's account, it is not very often that i need to use Lerz's account. i have used it in the past to unban someone that i had banned, only to re-ban them for longer as further grief had been found that they had done. i used the account today to spy on a suspected hacker, i used my account first obviously, but being restricted to only an invisible potion, the default could see my bubbles from the potion. i required Lerz's command of /vanish to investigate correctly and undetected.
the trust between lerz and i is unbreakable, if there was any hint of doubt in lerz's mind for me then i sure as hell wouldn't have his login details. if you must know, he has mine too. we just rarely use each other's account for the pure fact that for the most part they aren't needed.
i could understand if lerz gave his details to someone that isn't staff, but as i am staff already and have earned my rank through doing good and perseverance, I don't see much of an issue. its not like i use his account for bad things, i simply use it for a short amount of time and on rare occasions where i simply cannot perform actions using my own account.
Of course if it is a big issue for Luigi, i will not use Lerz's account anymore. Though i see little issue as i am staff already, the day that i abuse using lerz's account will be the day that you can complain with full reason that i cannot be trusted with the perms. lerz knows me inside and out, im pretty sure he would be able to see if i had bad intentions in mind by using his account.
Date sent: 2016/01/24 21:37:53
Penq, i said "Yeah he must be hacked, obvs" i told you it was me and you played along with me. i did actually tell people who were getting really worried and serious about the situation that there was nothing to worry about.
- you kicking me repeatedly, prevented a possible hack prevention.
**EDIT** Lerz was aware that i was on his account spying on someone, he always knows if i am on his account because i ask him prior to logging into it.
Date sent: 2016/02/03 23:02:45
Larsy is lerz? Try an IP check? Because everything they say seems so similar..
Date sent: 2016/02/03 23:12:03
I changed my password last week, so Chip being on my account won't be a problem anymore.
