Wowman2002 |
Date sent: 2015/12/11 16:11:49
We have another message for you. Do not publicly say it otherwise you will be banned from doing a certain thing, (you'll know what it is if you've decoded it), for the best 0111000001110010011010010110001101100101 you can find in-game.010001000110010101100001011100100010000001101101011001 010110110101100010011001010111001001110011001000000110 111101100110001000000101011101100101011000100110001001 100011011100100110000101100110011101000010110000100000 011100110110100101101110011000110110010100100000011110 010110111101110101001000000110010101100001011100110110 100101101100011110010010000001110011011011110110110001 110110011001010110010000100000011101000110100001100101 001000000111000001110010011001010111011001101001011011 110111010101110011001000000111000001110101011110100111 101001101100011001010010110000100000011101000110111100 100000011000010110001101100011011001010111001101110011 001000000110111101110101011100100010000001100010011011 000110000101100011011010110010000001101101011000010111 001001101011011001010111010000101100001000000111100101 101111011101010010011101110010011001010010000001100111 011011110110100101101110011001110010000001110100011011 110010000001101000011000010111011001100101001000000111 010001101111001000000110011101100101011101000010000001 100001011011000110110000100000011101000110100001100101 001000000110100101101110011001100110111101110010011011 010110000101110100011010010110111101101110001000000110 000101101110011001000010000001100011011011000111010101 100101011100110010000001101001011011100010000001110100 011010000110010100100000011011100110010101111000011101 000010000001101101011001010111001101110011011000010110 011101100101011100110010110000100000011000100111100100 100000011101000110100001100101001000000111011101100001 011110010010000001110101011100110110100101101110011001 110010000001100001001000000110010001100101011000110110 111101100100011001010111001000100000011010010111001100 100000011000110110100001100101011000010111010001101001 011011100110011100101101001000000100001001110101011101 000010000001101000011011110111011100100000011101000110 100001100101001000000110011001110101011000110110101100 100000011001000110111100100000010010010010000001110011 011101000110111101110000001000000111100101101111011101 010011111100001101000010100000110100001010010011010110 111101110110011010010110111001100111001000000110111101 101110001011000010000001101001011001100010000001111001 011011110111010100100000011101000110100001101001011011 100110101100100000011110010110111101110101001000000110 101001110101011100110111010000100000011011100110010101 100101011001000010000001100001001000000110001001101001 011011100110000101110010011110010010000001100100011001 010110001101101111011001000110010101110010001011000010 000001100010011011110111100100100000011110010110111101 110101001000000111011101100101011100100110010100100000 011101110111001001101111011011100110011100101101001000 000101100101101111011101010010000001101110011001010110 010101100100001000000110100101101110011101000110010101 101100011011000110100101100111011001010110111001100011 011001010010111000001101000010100000110100001010010100 110110111101101100011101100110010100100000011101000110 100001100101001000000111000001110101011110100111101001 101100011001010010000001100001011011100110010000100000 011011010110010101110011011100110110000101100111011001 010010000001101101011001010010000001010000010100100100 100101010110010000010101010001000101010011000101100100 100000011110010110111101110101011100100010000001100001 011011100111001101110111011001010111001001110011001011 010010000001001001011001100010000001111001011011110111 010100100000011100000111010101100010011011000110100101 100011011011000111100100100000011100110110000101111001 001000000111010001101000011001010110110100100000011011 100110111100100000011011010110111101110010011001010010 000001101001011011100110011001101111011100100110110101 100001011101000110100101101111011011100010000001110111 011010010110110001101100001000000110001001100101001000 000111000001110101011000100110110001101001011000110110 110001111001001000000111001001100101011011000110010101 100001011100110110010101100100001000000110000101101110 011001000010000001111001011011110111010100100000011101 110110100101101100011011000010000001101110011011110111 010000100000011010000110000101110110011001010010000001 100001011000110110001101100101011100110111001100100000 011101000110111100100000011101000110100001100101001000 000111011101100101011000100110001001100011011100100110 000101100110011101000010000001100100011001010110010101 110000001000000111011101100101011000100010111101100100 011000010111001001101011001000000111011101100101011000 100010000001100110011011110111001000100000011101000110 100001100101001000000110001101101000011001010110000101 110000011001010111001101110100001000000111011101100101 011000010111000001101111011011100111001001111001001011 000010000001100100011001010110011001100101011011100111 001101100101001000000110000101101110011001000010000001 101101011000010111010001100101011100100110100101100001 011011000010000001110011011101010111000001110000011011 000110100101100101011100110010000001110100011010000110 010100100000011100110110010101110010011101100110010101 110010001000000110100001100001011100110010000001110011 01100101011001010110111000101110 To solve Puzzle one you will need to use a special decoder which I'm not going to give you so easily now am I? Solve the puzzle to receive a link: 1. At the beginning of many links, there are 3 identical letters, correct? You will need them. 2.Add a dot after them 3 letters, decode this [eht melorp etis, decode it and write it correctly and all together] & write it after the dot. 3.What do letter/symbol do you use when writing a command in-game? Hint: it's the first one of every single command you do. 4.Insert that letter or symbol and proceed to decode then write this: [ 011100100110010101100110011001010111001001100101011011100110001101100101 ] after that letter or symbol. I remind you that there are no spaces in a link. 5.To give you a break, I'll tell you this one: After that work, add another one of those letters/symbols <--- The hint is right in letters/symbols if you haven't got it yet. After that second letter/symbol, add this " mathematics/codes/ ". 6.Add another letter / symbol after that. 7. Decode & add this: 011100110110100001101001011001100111010001100101011001 000010110101100001011011000111000001101000011000010110 001001100101011101000010110101100011011011110110010001 10010100111111 If there is any problem here since it includes symbolism, please message me with what you have decoded so far within that number & I shall directly give you a new puzzle. 8.If you've followed the steps correctly, you now have your link. Go there and decode our following message. Message to decode: Tp zpv ibwf ejtdpwfsfe b tfdsfu nfttbhf. Dpvohsbuvmbujpot, ju xbto'u bo fbtz qspdftt opx xbt ju? Jg zpv ibwf nbef ju uijt gbs zpv'sf tfsjpvtmz dmfwfs, dmfwfs bu cfjoh cbtjd uibu jt. Bozxbz, zpvs ofyu tufq jt up nbjm nf po uif gpsvnt ps jo-hbnf xjui uif xpset "J ejtdpwfsfe zpv'sf tfdsfu nfttbhf, hjwf nf uif ofyu tufq boe J tibmm qspdffe po uif dzcfs bewfouvsf zpv ibwf hjwfo nf, JWJWJ". Ep uijt up sfdfjwf gvsuifs jogpsnbujpo po ipx up bddftt pvs xfccdsbgu xfbqposz, bsnps, fyqmptjwf, nbufsjbm, tbmf. Hppe qsjdft, xpsui zpvs ujnf. Cz uif xbz, jg zpvs gspn Izqfsjpo J tvhhftu hpjoh uif gvdl bxbz, zpv bsf jo uif xspoh qmbdf. Best of luck. Sincerely, -W. |
Lerz |
Date sent: 2015/12/11 16:51:34
Got eeeeeeem! Hahah :> |
stojan44 |
Date sent: 2015/12/11 17:00:54
haha! hilarious and original! totally! ._. |
Wowman2002 |
Date sent: 2015/12/11 21:02:20
xD |
Date sent: 2015/12/12 00:29:40
Way to ruin the forum layout... couldn't you have added in a few new lines or spaces? |
Gavin |
Date sent: 2015/12/12 05:56:01
So why don't you add a new rule "no making very long lines on the forums" |
Wowman2002 |
Date sent: 2015/12/12 07:31:41
I did Luigi but for some reason it came out like that, it originally came out as a massive block of text but changed when posted. |
Date sent: 2015/12/12 15:06:07
Of course it's going to come up as a massive block of text in the typing box because the layout of that doesn't change as you type.Nevertheless, I fixed it. |
Wowman2002 |
Date sent: 2015/12/12 15:49:38
Thanks! |
