KGEvans |
Date sent: 2015/03/17 08:55:50
This is another "short" guide by KGEvans. I will be covering all the permissions you have specifically for the Donator ranks. (VIP+, Builder and Donator+)----------------------- VIP+ Commands ----------------------- getpos - This will display your position, similar to F3 however in a more user friendly format in chat. fly - This will toggle the fly ability. Once it is on double jump and you will be flying. Remember that this will be turned off when you log out, so make sure you are on the ground when logging out or you will take fall damage. tp - This allows you tp teleport to a user. This is similar to the tpa command, however it does not require the other party to accept. This is to be used for convenience and not for abuse. Abuse can get you banned and/or the command removed from you. feed - This restores your hunger to full. heal - This restores your health and hunger to full. workbench - This will open the display for a crafting table without the need for having a crafting table near you. lightning - A command that causes lightning to hit the ground where you are looking. Also can be done with smite. Abuse of this command will get you a ban and/or the command removed from you. near - Displays all the close players to you in your chat. sell - This allows you to sell an object from your hand without the need to going to the server shop. setwarp - This allows you to create a warp for people to visit. broadcast - Sends a message to the server that stands out from other text. Typically used for MushroomCo related information. Not to be used for personal chat or mute evasion. compass - Displays the direct you are facing in your chat. depth - This will display how many blocks you are below or above sea level, it will not show you the Y axis however you can work it out. recipe - This will open up a crafting table showing you how to make an item you put in chat. It can be useful if you forget how to make certain things. kittycannon - A fun command that shoots out a cat that explodes. The explosion does no damage to blocks or entities. jump - This allows you to jump up to the nearest gap of air or forward through a non-solid object. tree - This will allow you to spawn in a tree of your selected type. (Does not currently support any of the 1.8 trees) seen - Displays the last known time someone was online and also if they are currently Banned. hat - Puts the block in your hand as your helmet, for all your fashion needs. top - Sends you to the highest block on the spot you are standing. tptoggle - This will block anyone else from teleporting to you. This does not stop mods and admins as they have an override teleport. ignore - This will block a person in the chat from talking to you. --------- Builder --------- gamemode - This makes you able to go into creative. You may also use gmc and gms to go to creative and survival respectively. Do not give out creative items as it is against the rules and will ruin the server economy. give - This allows you to give an item of your choice. You just need the name of the item or the item code. Again do not use for other's benefit. clear - This will clear all items out of your inventory, however does not remove armour that you have equipped. ------------ Donator+ ------------ god - You will be fully healed and fed as well as become immune from damage and will no longer lose hunger. You also are disabled from PvP with this on. kill - The ability to kill yourself or others instantly. This is used to assist moderating the server for when mods are not online. Do not abuse or you will be banned and/or this command will be removed from you. kick - The ability to kick people from the server if they are misbehaving. This is used to assist moderating the server for when mods are not online. Do not abuse or you will be banned and/or this command will be removed from you. spawner - Using this you can change the type of a spawner. Some of these may be disabled to prevent abuse. xp - This displays how many xp points you have. time - This displays the time of the server in your chat. weather - This allows you to use rain or sun to change what weather there is. enderchest - Opens an enderchest interface for easy access to the enderchest. baltop - This displays the top players of the server and their balance. i - Instantly gives your self a stack of the item you put in. invsee - This allows you to look into someones inventory to see what they have on them. This can sometimes help diffuse certain arguments. killall - This allows you to kill all mobs around you. enchant - The ability to enchant the item in your hand without the need for an enchantment table. repair - This allows you to repair objects in your inventory. A simple way to fix everything is repair all. remove - This allows you to remove entities in a selected radius. This allows you to remove certain objects that can cause lag. ---------------- Other Perks ---------------- VIP+ - The ability to use colours in chat and in nicknames - Use magic text in chat and books - Write colour on signs - Create warp signs (Please be aware only admins can remove these) - 10 homes Builder Most of the comands from VIP+ Donator+ All commands from VIP+ and Builder - Allows bold, italics and underline on signs - Unlimited homes ------------------- Donator Rules ------------------- You may also find these at spawn. 1. Do not abuse powers. 2. Do not give out or sell items that are spawned in. 3. Do not PvP in creative. 4. Do not spawn massive amounts of entities. 5. Do not teleport and harass people. 6. Do not use or create OP items. 7. Do not impersonate staff. 8. Do not use the abilities for other's benefits. 9. Do not teleport too far away from spawn. ---------------- Other Notes ---------------- To become a donator you may donate here http://webbcraft.co.uk/donate.html and select the package you want. If you want to upgrade from a lower package simply donate the required amount to make it full using the any amounts in the lower part of the page. Once you have donated don't forget to message luigiofthebakery in game when he is online or by doing /mail send luigiofthebakery. This document may become outdated, some of the abilities may end up at a different rank or be removed all together. I will try to keep this up to date as much as I can. If you find any issues please mail me in game. -KGEvans |
Wowman2002 |
Date sent: 2015/03/17 14:24:52
Lol you just wasted ur time. U can find this on the donate forum but still, good job. |
darkexpress |
Date sent: 2015/03/18 18:51:44
Nice job KGEvans I don't know why you still aren't mod yet |
KGEvans |
Date sent: 2015/03/19 07:56:33
I did it because someone said they don't know what they are doing now they have donator+ so I made this guide. |
Wowman2002 |
Date sent: 2015/03/19 09:11:19
oooh lol |
Wowman2002 |
Date sent: 2015/03/30 10:37:52
How to make the moving writing? |
Milocooper |
Date sent: 2015/03/31 15:41:55
This is really cool!! |
KGEvans |
Date sent: 2015/03/31 18:01:05
@Wowman2002 the "magic" is &k and don't forget to reset it so the rest of the words aren't like that with &r.You can find all the codes on here: http://minecraft.gamepedia.com/Formatting_codes |
