Date sent: 2018/08/28 14:35:22
1. Add a lock type that makes it so others can't lock or break the locked unit, but everyone can still use the unit as if it isn't locked.
2. Add a faction-only lock type.
3. Add an option for a blacklist lock rather than just a whitelist lock. |
Date sent: 2018/08/28 17:47:35
i might be wrong with this or the commands are currently glitched but we have 2 of those to my knowledge at least.
1. /cpublic
2. this is the one that is currently glitched, usually it would be just unlocking the chest that would allow it to the entire faction and nobody outside the faction would be able to access it. but that one is currently glitched so an alternative that could be used would be using /cpassword <password> and then telling your faction members the password to it so you dont have to /cmodify them all to it.
3. i havent tested this yet but you might be able to use /cmodify -<name> to restrict players from it but im not exactly sure with this |
Date sent: 2018/08/29 02:51:59
1. Oh, sweet. That's good to know.
2. I mean if you use unlock, even non-faction members should be able to use it, while faction lock is faction members only.
3. /cmodify is a whitelist lock, not blacklist. |
Date sent: 2018/08/29 07:36:34
Faction locks will be fixed when the server next restarts. I'm pretty sure lwc already has the other two things. |
