The plugin to stop xrayers
Pyrrhus
Date sent: 2017/10/21 18:21:00
I've noticed that there's alot of x-rays bans and People claiming innocent.So I found a plugin called Orebfuscator. It will generate fake ore making x raying harder
I'm not to sure how much lag it cause to the server could figure that out but I heard it would lag the hacker
Date sent: 2017/10/23 05:22:37
Date sent: 2017/10/23 21:09:29
*Looks into ravine*
*Sees diamond ore*
Me: "Sweet! I found diamonds!"
*Mines diamond*
*Diamonds turn out to be fake*
Me: "FUUUUUUUU"
Pyrrhus
Date sent: 2017/10/24 02:01:49
I see your point Presinus
But based on my understanding on the plug in it only shows as fake ore only if it is fully covered by something so if there is a air block next to it. It won't show as a fake ore
example of it working
Date sent: 2017/10/24 03:01:54
Well if that's true, +1.
Date sent: 2017/10/24 03:39:05
Sometimes people with lag can catch a glimpse of fake blocks in engine mode 2 before they update. Also it's much laggier on the server, which is why I would rather use engine mode 1.
Date sent: 2017/10/24 10:26:13
You shouldn't use any engine mode. It's fun when Zed catches xrayers and they try so desperately to escape.
