Crazygecko1121's Moderator Application
crazygecko1121
Date sent: 2014/11/24 01:56:30
Deleted
Date sent: 2014/11/24 22:12:16
no, this is not the 100th moderator application, and just looking back through the applications now I see you have already previously posted one on the 5th of August and then another again on the 19th of September, making this the third.
As I told Inchulk2013 through a reply to his third moderator application on the 16th of September,
"If you want to add more information to your application or update it please only use one topic and don't post new ones as it spams the forums."
If you want your application to appear at the top of the list so that people can see it, add a reply, because topics with the newest replies appear first.
Furthermore, it should be in your interest to use an older topic instead of posting new ones because by continuing to update an application with an older creation date, it looks like you have been waiting to become a moderator for longer and therefore are more likely to be accepted.
