 RaineoThatNerd
Date sent: 2015/02/27 00:15:33
Rly Hazza as a Staff Member Should Know How to Fix Commands When Needed to
Yea Sure Hazza You can Dish It Out But You can Clean Up After yourself!
P.S Rudeness My Ass! Your Allowed to Swear! And You Know That! |
 HazzaB
Date sent: 2015/02/27 01:05:39
Yes, but pouring lava buckets on players is not. I saw enchanted diamond tools get destroyed by your antics. Then telling staff to "Shut up" is against rule 3 as well as the general "respect other players" rule.
The reason I struggled to repromote you is because I don't have access to any of the Group Management commands apart from ManuAdd which is a hinderance. I can't even get /listgroups which is the command I need.
Due to your rudeness and lack of remorse I decided to not go easy on you and just demote you, but to instead tempban you for 3 days for breaking rule 1, 3 and 9 |
 Mumfie
Date sent: 2015/02/27 01:10:02
Maybe if you ask really nicely he might reduce the punishment to 1-2 days, Hazzy is actually quite a nice guy. :)
Right Hazzy?! :D |
 HazzaB
Date sent: 2015/02/27 01:50:41
I'm lovely :3 Though if you want to be unbanned sooner, I'd reccomend going to the ban appeal section.
And avoid straight up offending anyone in it. Please don't capitalise every word as it makes it harder to read |
 llamasgobing
Date sent: 2015/02/27 10:03:12
Raineo, you did break rules and abuse your donor commands, he was in the right to punish you for what you've done, Hazza is a smart lad, he knows how to fix his command mess ups, and this one isn't a mess up by the sounds, you'll get your commands back soon enough, if your appeal is accepted and you decide to be on your best behaviour.
~Clock xx |
 RaineoThatNerd
Date sent: 2015/02/27 16:08:03
Im Not Talking About What I did
Im Saying Hazza Should No Do Command HE does not Know How To Fix |
 HazzaB
Date sent: 2015/02/28 19:49:33
And as I explained, I can't repromote to Donator+ because I don't have access to the command I need to do so; /grouplists
Also taking over the Plug DJ channel and locking it was a childish move. Your channel is no longer the unofficial server Plug DJ Channel |
