Forum Index > Suggestions > New ranks :) > Read the topic
New ranks :)
Date sent: 2015/02/10 21:33:33
I think that we should bring back the trusted rank, only higher in command.
Trusted
The trusted rank should be in between donator and helper, And has more abilities to stop bad situations. Trusted should have the donator rank perms, temp mute, and some co commands.
Trusted +
Trusted + should be like trusted, but with more /co commands and temp ban.
Conditions
Only donator+s should get these ranks, and must follow in the corresponding order:
Donator+, Trusted, Trusted+
I hope you take this into consideration,
SireJordz_
(I will use this topic to jot down other ideas)
Date sent: 2015/02/10 21:42:32
Another name for trusted+ could be Junior mod or maybe helper is changed to junior mod, and then trusted + is helper. Idk
Date sent: 2015/02/11 00:32:46
I think trust and trust+ should be upgrades from member and citizen plus, however these ranks should only ever be given out by luigi himself.
Date sent: 2015/02/11 08:32:20
One of the main factors of ranks is that permissions given to those who have donated are never given by default to someone who hasn't donated, which is why if these ranks were implemented, they could not be upgrades from member or citizen+.
But in the rank system, 'Trusted' was the original name for the VIP rank, and still remains the official group name for that rank. This was because the rank was originally like a member rank when the server was much smaller, before donator ranks (pre 18th February 2013)
crazygecko1121
Date sent: 2015/02/12 22:01:38
*cough* helper needs more perms *cough*
Date sent: 2015/02/13 06:09:47
Yes luigi, I do remember the trusted rank, but what I am saying is to bring it back although higher in command (As I stated, above donator). This may be trouble adding the group the group manager, but it could be called something else, as I said. I would also like to point out that I am not saying to take out vip+, I'm saying to add trusted as another rank.
Thanks!
Date sent: 2015/03/28 21:26:53
- 1 - Bump If you have read Dig's topic.
- 2 - How about:
*Add the trusted rank for a start. If no one abuses, slowly bring in trusted+. This will prevent from abuses, but it will also kickstart the idea.
Date sent: 2015/04/12 16:58:58
good idea
