 itstommy68
Date sent: 2017/10/13 14:25:52
I was banned 2 weeks ago for 5 days, that ran out i went to join the server and it told me i had to wait another 5 days so i contacted a admin ZedCall, and he didnt respond, then i go to join again today and it now says i have to wait 6 more days.. |
 ACeTheGreat98
Date sent: 2017/10/13 17:25:36
Two things;
One, our format is...
Username:
Why you were banned:
When you were banned:
Two, it appears you may have changed your username, and if you have, you will not be able to be unbanned until you change it back. |
 OfficalMinoi
Date sent: 2017/10/24 21:03:33
Date sent: 2017/10/26 02:23:26
why would you +1 this minoi...
Two, it appears you may have changed your username, and if you have, you will not be able to be unbanned until you change it back.Two, it appears you may have changed your username, and if you have, you will not be able to be unbanned until you change it back.Two, it appears you may have changed your username, and if you have, you will not be able to be unbanned until you change it back.Two, it appears you may have changed your username, and if you have, you will not be able to be unbanned until you change it back. |
Date sent: 2017/10/26 10:44:18
Correct me if im wrong Ck but I believe he can +1 a ban appeal if he wants, regardless of their physical ability ability to be unbanned due to name change or similar. |
Date sent: 2017/10/26 16:33:05
You are correct Loki
also +1 |
 Pheo
Date sent: 2017/10/27 12:13:49
+1 Luigi sorted out this problem with someone who hasn't changed usernames |
