HazzaB |
Date sent: 2014/12/27 09:59:32
DefaultsLose: access to /nick for quicker response to hacking/spamming/griefing Gain: /spawn, "/kit tools" having a rulebook. It's a very easy command to add/change kits, granted a book with text in it would be a lot harder than a regular item Helpers Gain: /hat Mostly for Helper Banner Hats I've heard of many people claiming /pvp not to work but not seen it myself. Also heard it sometimes switches to true when logging off, maybe set default to off? Spawners can now be changed by right clicking them with a mob egg, even in survival mode. This means you can effectively buy spawners if you buy a mob egg from /warp shop. Something to think about either removing/changing price/keeping things as they are World Border to be reduced to stop people going too far away from spawn. Make the damage tick very slow and global mail to warn people. Might be best leaving this one until the new map Maybe a random warp pluggin for the wildy with a new map too, so you dont get one griefed starting area I'll use this topic to just jot down ideas I come up with |
Blueroon |
Date sent: 2014/12/27 16:51:24
I think these are good ideas except you wouldnt have to get a new plugin for the random warp if command blocks were enabled, same with the spawning with the rule book. |
futuretiger |
Date sent: 2015/01/08 21:03:53
I think most ideas are great, but world border I feel might eventually get to be a problem in updates. For example, if an update were to happen and they add a new ore, it couldn't be found in previously spawned chunks. |
HazzaB |
Date sent: 2015/01/11 06:19:16
Even within 3000 blocks from spawn you can do /f map and see no claimed chunks, so I think even a 10k border would suffice. This allows room to extend the world border for future updates.New Ideas: Maybe a new rule not to build structures in creative out of "precious" blocks like diamond or gold blocks, since its grief bait to your faction members. At least make it so they shouldn't build that sorta stuff in the wilderness where it 100% gets griefed Turn off explosions in War Zones. Too many times the pvp arena's get blown up by people spawning in creepers. If u can't change the explosions off, have a pvp rule of no mob eggs in arenas, unless agreed to before hand (Kinda like how I want the pvp rule to be) A command block and button to be added to the spleef arena to un-spleef the whole pitch with snow I had a few ideas in here before but the login time ran out and I lost it. I'll just post a new reply when the idea's spring into mind. |
Tones |
Date sent: 2015/01/12 09:09:03
+21 i love that idea Hazz |
HazzaB |
Date sent: 2015/01/13 05:43:14
Builders to get access to &l-&o when writing on signsImportant: Make it so I can leave messages with /tempban the same way you do with /kick and /ban. Not being able to leave messages means I have to choose between tempbanning them and them not knowing why or banning them with the reason and asking them to appeal on the forum OH! And also there is no confirmation when the temoban goes through. No yellow text saying X tempbanned Y for Z days |
futuretiger |
Date sent: 2015/01/13 20:46:49
These are all very good ideas, but there are two things that should be pointed out. First, command blocks aren't enabled, and second there are already fac bases past the 10k block radius. |
HazzaB |
Date sent: 2015/01/14 03:23:45
Command blocks are enabled for anyone with OP, ie Luigi. He can write the command and leave a button on it so anyone can "use" the command in the command block ie refilling spleef arena.I suggested the world border be used for the next map, not the current one. I also said (as did Luigi) that the max distance is 30k. I was merely using 10k as an example if you actually read my posts carefully. I guess this is a suggestion: Move the entire "/warp pvp" arena (And the blocks underground to include the redstone) 10 blocks to the east so the arena is on the edge of the war/safezone. This'll stop people attacking others outside the arena door Change the sign at spawn that says voting for the server gives you a % chance of gaining citizen+. It's not worked for a long time now and voting doesn't even pay your player on the server, so maybe look into fixing that |
Date sent: 2015/01/15 11:16:03
The construction of structures in creative mode purely out of "precious" blocks like diamond, gold and emerald are already prohibited under the OP items rule.The idea of having a command block to regenerate spleef is very good and is now possible with the 1.8 /fill command, so I'll try and do it soon and hopefully people will start using the spleef more! The warp pvp will be moved as soon as WorldEdit is back on the server. Builders don't get &l-&o when writing on signs because it's only for donator+ And with the tempban messages, I should be able to do that, in fact I'll get started on it right now. |
Date sent: 2015/01/15 15:17:27
Completed adding reasons to tempban. |
RaineoThatNerd |
Date sent: 2015/01/18 12:18:48
Nothing To Do With This PostI just Realised That Luigi has a browny orangy Moustache, Cool |
Willhayter1 |
Date sent: 2015/01/18 17:39:09
+1 Hazza. Nice to see someone is taking a pro-active approach to improving an already awesome server. |
Rex |
Date sent: 2015/01/19 09:52:36
Slight problem with cmd blocks.The trolls. Abusing TP cmd and killing and spawning precious jewels. |
Rex |
Date sent: 2015/01/19 09:53:22
/Nick help |
HazzaB |
Date sent: 2015/01/22 02:17:20
If you problem is you can't use command blocks Rex, then its not a problemComplaints about people should go in the Complaints section, this is for improvements using /nick already gives you help text |
HazzaB |
Date sent: 2015/02/01 02:05:54
Aaaaand he's backI'd love to be able to CTRL+Pick Block to copy entire chests like in vanilla minecraft. CTRL+Pick Block works on banners but unfortunately not on chests. Temp Mods seem to just add staff perms onto their previous position rather than giving them an entirely new set of perms. THis means temp-mods promoted from builder don't have the same commands as those from Donator, and even less if they were Citizens. Main commands include /seen. /fly and /bc for staffing purposes How have I not written this one down here yet!: Core Protect to only wipe the oldest 50% of its data when it reaches Max Data Capacity rather than 100% of it. Having all data removed means any griefing that happened before the wipe can't be fixed which means every 2 weeks or so I have to tell someone there is nothing I can do to fix their build |
IAPhoenix |
Date sent: 2015/02/01 06:09:33
"I've heard of many people claiming /pvp not to work but not seen it myself. Also heard it sometimes switches to true when logging off, maybe set default to off?"The server message reminding new players that this command exists uses the wording "/pvp off". If you type /pvp off it doesn't actually work. You have to type /pvp false. So maybe that is why people claim that /pvp doesn't work. Maybe fixing the broadcast message would clear up this issue : ) |
Date sent: 2015/02/08 07:15:42
Actually, the server auto-broadcast message states to "type /pvp to toggle pvp on and off for yourself to prevent being killed". It uses the words on/off to describe the state of your pvp, but not what you should type with the command.I don't know how to fix the CTRL+Pick Block to copy entire chests as that's more involved in the mechanics of the actual server itself, and not a plugin issue. With the ranks, it's actually the opposite, and intentional. When someone is promoted to moderator, they are given an entirely new set of perms from the moderator rank. However, this doesn't include permissions from the donator ranks, so if they have donated the permissions from the donator rank need to be added on. It's often mistaken that the moderator rank gets all donator permissions, but this isn't true, so if someone who hasn't donated becomes a moderator they won't get the extra permissions that someone who has donated gets. With the CoreProtect database, this is a good idea, I'll try and set up a script that will delete the oldest entries periodically, say every 2 weeks, but this might not be very reliable because the amount of data entered into the database varies based on player activity of breaking and placing blocks. |
