Warning about the nether
Date sent: 2016/06/09 16:13:59
Im afraid to tell you that the nether portal is broken in 1.10
I dont know if this is just on the server or if its a minecraft issue. When you go through the portal you will be teleported to the void. You will die if you are in gm s and gm c. And if you die in the void your items will be lost and wont be recoverable. After you die and respawn at the server spawn if you do /back you will be in the nether.
A quick note:The end seems to be fine.Also I posted this in the wrong section so can fourm staff move this to General
Date sent: 2016/06/09 16:26:37
I noticed this issue. Although are you sure it is the void?
When I experienced the bug, I was a few thousand blocks above sea level (y: 5000 - 8000), still isn't good - but you should be able to recover your items once you have died.
Either way if this is in the void or if it just tp's you really high, you should be able to /back or /spawn or /home before you die.
Date sent: 2016/06/09 16:28:18
Yes its definitely the void.
Date sent: 2016/06/09 19:59:35
Well that's because 1.10 has new items for the Nether...Luigi just has to delete the old one or maybe recode it
Date sent: 2016/06/10 15:37:45
The nether is still there its just the Portals that are broken Cloudy.
Date sent: 2016/06/10 17:59:55
Thanks for the warning kind citizen I shall return the favour
Echo is an attention whore be warned
Mumfie
Date sent: 2016/06/10 23:55:15
Hahaha what the fuck Harvey. 11/10
Date sent: 2016/06/15 09:24:35
Nether portals are now fixed.
Date sent: 2016/06/16 16:18:21
Ok thanks for letting us know luigi
