I Keep Losing Connection No Matter What I Do
bloxer123link
Date sent: 2016/04/21 19:15:40
this is the error i keep getting someone named superdude445 gave me stacks of chests that say COPY ME so i placed one of them down and got disconnected i relogged got this message and now i cant get back on the server. this all happened when i was helping El_Glovenator build something
[Error Message]
Internal Exception: io.netty.handler.codec.DecoderException: Badly compressed packet - size of 4402710 is larger than protocol maximum of 2097152
if anyone knows how to fix this please help because i have tried everything from re-adding the server to deleting minecraft. folder and re-installing it
[Update]
the server crashed and i recieved a crash report never has that happened until now
Completely ignored arguments: [--nativeLauncherVersion, 301]
[15:28:54] [Client thread/INFO]: Setting user: bloxer123link
[15:28:56] [Client thread/INFO]: LWJGL Version: 2.9.4
[15:28:57] [Client thread/INFO]: Reloading ResourceManager: Default
[15:28:58] [Sound Library Loader/INFO]: Starting up SoundSystem...
[15:28:58] [Thread-4/INFO]: Initializing LWJGL OpenAL
[15:28:58] [Thread-4/INFO]: (The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org)
[15:28:59] [Thread-4/INFO]: OpenAL initialized.
[15:28:59] [Sound Library Loader/INFO]: Sound engine started
[15:29:00] [Client thread/INFO]: Created: 1024x512 textures-atlas
[15:29:14] [Client thread/INFO]: Connecting to mc.webbcraft.co.uk, 25565
[15:29:17] [Client thread/INFO]: [CHAT] ~ Wilderness
[15:29:17] [Client thread/INFO]: [CHAT] bloxer123link joined the game
[15:30:35] [Client thread/INFO]: Connecting to mc.webbcraft.co.uk, 25565
[15:30:37] [Client thread/INFO]: [CHAT] ~ Wilderness
[15:30:37] [Client thread/INFO]: [CHAT] bloxer123link joined the game
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff8eb6d6a27, pid=7404, tid=8340
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig8icd64.dll+0x16a27]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\leehi\AppData\Roaming\.minecraft\hs_err_pid7404.log
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Date sent: 2016/04/21 22:24:39
Maybe he trolled you? I think it might of been cause the chest was named, I really don't know.
JamesSkullBlood
Date sent: 2016/04/21 22:47:11
No it a chest hack l3gend
Date sent: 2016/04/22 02:44:11
Hey Bloxer. I might have a solution, but it might sound weird but that's the same problem my friend had. Try using another 1.9 version if possible. He was on Mine**** server and he was kicked and it said that there was to many packets sr something and he said that's because he was on 1.9. That's all what I have.
bloxer123link
Date sent: 2016/04/22 04:04:18
thanks anyway but the problem has already been sorted out but i do appreciate the suggestion
Date sent: 2016/04/23 09:19:28
How was it fixed?
Sparqy
Date sent: 2016/04/23 18:52:53
Luigi, James cleared his inventory.
There was a recent player online using a hacked client-- the person used this tool that would create chests with massive amounts of data that would crash the person given to, so I'm assuming bloxer was a victim.
