sonicfastman123 |
Date sent: 2016/04/21 17:19:48
i was recently disconnected and have been unable to join due to something about a "badly compressed packet" im not sure if ive been banned or not or if its something wrong with my client, please inform me ive been kicked or banned because i believe i havent done anything wrong. |
Chip_Bruh |
Date sent: 2016/04/21 18:50:39
you are not banned.i think that this is an error with your internet failing to provide sufficient download speed for joining the server. try going into your video settings and lowering the render distance to 5, then try and reconnect. i have had a look around on a few forums and i cannot see any complaints of this happening in 1.9(.2), only in 1.7 and 1.8 when there was a few issues with spigot. As mc.webbcraft.co.uk is powered by spigot, i am not sure if this is another 1.7 / 1.8 issue that has transferred into 1.9 - but then i am not sure if this issue would effect the rest of the server. i will ask luigi to update the server and see if this fixes your issue, if my previous diagnosis is inconclusive. if you have any different kick/failed to connect messages then definitely screenshot them and send them here, or just copy the exact message from your client logs. |
thomasjones |
Date sent: 2016/04/21 18:54:34
I belive that someone in not sure who did something to a chest that makes anyone who use it get kicked and fail to rejoin...im not 100% sure of the details so ask eddie |
bloxer123link |
Date sent: 2016/04/21 19:01:12
i have the same problem!!!!!!!! ;-; someone gave me a chest that said COPY ME i placed it down not knowing it had something bad and now i cant login because of that i blame superdude445 if anyone wants to know who is going around giving people chests that say COPY ME |
bloxer123link |
Date sent: 2016/04/21 19:04:05
i also tried lowering my render distance down to 5 but that does not work ;-; |
bloxer123link |
Date sent: 2016/04/21 19:05:34
superdude445 is to blame all this started cause i placed down a chest that superdude445 gave me that said COPY ME |
thomasjones |
Date sent: 2016/04/21 19:34:09
Btw superdude445 has been banned if that helps |
bloxer123link |
Date sent: 2016/04/21 19:40:28
i guess it does but it does not help me re-log mainly cause im not able to go on |
bloxer123link |
Date sent: 2016/04/21 19:42:08
im still getting the same error message. the thing is i need to delete the chest i placed down infront of me and you can find it in El_Glovenators build were i was helping him just ask if i was helping |
bloxer123link |
Date sent: 2016/04/21 20:07:43
also this the error message if no one saw my topic no one even bothered to respond :/Internal Exception: io.netty.handler.codec.DecoderException: Badly compressed packet - size of 4402710 is larger than protocol maximum of 2097152 |
thomasjones |
Date sent: 2016/04/21 20:49:03
Im not sure why the msg is comming up,have u set ur render distance to 5? |
bloxer123link |
Date sent: 2016/04/21 20:50:49
ive done that already and im still getting that message ;-; |
bloxer123link |
Date sent: 2016/04/21 21:01:14
http://bloxer123link.imgur.com/all/ |
JamesSkullBlood Moderator |
Date sent: 2016/04/21 21:07:31
I believe superdude445 was hacking with that and I would recommend changing your password (everyone that been affected by the chest that superdude445 gave you) because it probably was like that book hack thing where you open it and click a link and then they have OP or something like that. |
bloxer123link |
Date sent: 2016/04/21 21:08:13
alright |
bloxer123link |
Date sent: 2016/04/21 21:12:40
im still getting the message as of right now when can it be fixed am i the only one who got tricked into opening a chest :/ i mean i saw sonics message but idk if he also opened a chest saying COPY ME |
bloxer123link |
Date sent: 2016/04/21 21:29:05
http://i.imgur.com/zugoK25.png |
bloxer123link |
Date sent: 2016/04/21 21:29:32
alright well that time i posted the link correctly |
bloxer123link |
Date sent: 2016/04/21 21:50:19
this is already starting to become very fustrating :/ |
Date sent: 2016/04/21 22:19:58
Yeah what that was a hack called crashchest and me or a admin needs to /clear your inventory so I'll need your ign and same for sonic to remove the items in his inventory as this is the only way. |
Date sent: 2016/04/21 22:34:46
I can't clear y'all inventories because ya not on only Luigi can at this point sorry |
bloxer123link |
Date sent: 2016/04/21 22:50:48
does IGN mean in game name or like IGN well if its from IGN its the same as in IGN and in MC which is bloxer123link also i dont mind my inventory being cleared at least i have no diamond iron or coal accept my 2 most rare picks but il get them back :3 |
Date sent: 2016/04/21 22:52:37
I can't clear your inventory only Luigi can unless you can get on minechat which I don't think you can |
bloxer123link |
Date sent: 2016/04/21 22:53:59
il try that |
Date sent: 2016/04/21 22:55:20
If i see you join I'll try to clear your inventory fast I'll reply back if I see got you joined |
Date sent: 2016/04/21 23:02:13
Sonicfastman get on minechat and I'll clear your inventory but I need your in-game-name |
sonicfastman123 |
Date sent: 2016/04/22 07:09:27
hello james, i can confirm that i was disconnected after i got the chest that read 'copy me'. my ign is 'Sonicfastman123' |
sonicfastman123 |
Date sent: 2016/04/22 07:15:06
**admin: removed for security** i believe this is what he used to accomplish what is happening |
sonicfastman123 |
Date sent: 2016/04/22 07:23:47
i also cannot connect on minechat |
Date sent: 2016/04/22 11:08:51
OK I'll let Luigi know when I see him to clear your inventoryAnd that link was what I have Found as well |
Date sent: 2016/04/24 12:49:51
Luigi had cleared your inventory sonicfastman123 so you can join now |
