 cptjacksparrow42
Date sent: 2015/12/07 01:37:32
What I'm suggesting is possibly a command block creations contest. We could have players design contraptions mainly out of command blocks and redstone. Then the judges maybe do a survey to decide which one's the funnest. |
Date sent: 2015/12/07 04:13:10
-1 |
Date sent: 2015/12/07 07:19:01
No one below opped staff members will ever have command block access. You could easily destroy the server with a few sentences. Command blocks bypass all plugins which means you can edit land like spawn, safe zones, war zones, or faction land. As command blocks are not counted as an entity or anything that causes land edit, core protect cannot roll it back. The only option is for luigi to launch the server backup which is a save of the world before the damage would have been caused. Which isn't easy and is quite strenuous.
So no. You're not having access to command blocks. |
Date sent: 2015/12/07 08:49:24
-1 |
 miketikel7
Date sent: 2015/12/08 03:01:05
-1 too dangerous, but a good idea |
 cptjacksparrow42
Date sent: 2015/12/12 04:32:03
Yeah I suppose you all have a point there. |
