Forum Index > Suggestions > Movecraft > Read the topic
Movecraft
pylonmaster
Date sent: 2015/05/14 14:50:36
I think movecraft would be a great addition to this server here are some reason why:
1:It would enhance gameplay alot
2:players would ahev a new cool thing to do
3:it would make this server more unqiue
4:Airsship battles could eb had.
Date sent: 2015/05/16 06:19:54
Hi Pylon Master.
I'm glad to hear that you'd like improvements in the server. I could not find any updated plugins named "MoveCraft" although I have found one very similar plugin named "Ships":
http://www.spigotmc.org/resources/ships.2072/
Although I'm not sure weather this requires forge or another loader. If it does, we wouldn't install it as it would make us no longer a semi-vanilla server.
If we had a minigames world, this might be a good idea for a minigame to implement to the server.
Regards,
Jordan
Date sent: 2015/05/16 12:43:50
What is this? Could you describe what 'movecraft' is?
Date sent: 2015/05/16 18:27:00
I am guessing by the name and "airship battles" it is a vehicle generating plugin. It sounds EPIC so pls pls PLS install it luigi
Date sent: 2015/05/16 20:27:11
Movecraft is a plugin that has been designed to give purpose to those extremely large (and awesome) oceans as well as to simply give the option to Sail, Drive, or Pilot amazing Ships, Creations, or Zeppelins. It allows the player and/or players to craft Vessels out of blocks that can be piloted and thus moved. Hence the name MoveCraft.
Credit
Movecraft was first created by Yogoda for hMod.
Movecraft 3 is a complete recode. It's only similarity to the Movecraft of Yogada is it's name.
Documentation, Tutorials, Quick Start Guide, and Demo Videos
For documentation and information, use this link:
http://www.planetminecraft.com/mod/movecraft-reloaded---loraxe42s-fork/
Also the builds on that site are more up to date than the builds on this site, so download the latest version there. Please be aware the builds on that site have not been checked by the dev.bukkit.org staff, so use at your own risk.
Here is a brief summary of Movecraft features covered on that site:
Control Method Options
Sign and Pilot Tool
Sign only
Direct Control (the players movements control the craft)
Misc Commands - /manoverboard, /release, etc
Remote Signs to remotely activate command signs from other parts of the ship (Turn turrets, launch torpedoes, etc)
Craft Options
Basic craft configuration options including size, speed, allowed block types, required blocks, etc
Customizable Cruise Control to keep the craft moving forward
Customizable Fuel Burning behavior
Customizable sinking/crashing behavior including smoke, explosion on impact, and uncontrollable dives
Restricting motion to horizontal or vertical planes
Customizable "Hover" land contour following behavior for cars and surface vehicles
Optional craft teleportation
Require water contact for sailing ships and water craft
Crafts that explode when they collide with things for ramming or torpedoes
Repair signs to repair your ship, requires mats, and can require a fee
Server Options
Customizable Pilot Tool for craft control (or you can disable it to force sign only movement)
Man Overboard timeout to allow anyone who falls out of a craft to get back in it
Configurable WorldGuard protection against moving into forbidden areas or sinking over protected areas
Permissions
Movecraft uses the following permissions:
movecraft.<craft name>.pilot
movecraft.<craft name>.move
movecraft.<craft name>.rotate
movecraft.<craft name>.repair
For example, if you have a craft named "Airship", you would need movecraft.Airship.pilot, movecraft.Airship.move, and movecraft.Airship.rotate in order to completely use it.
There is also:
movecraft.<craft name>.create - only required if RequireCreatePerm is set to true in config.yml
movecraft.cruisesign - only required if RequireCreatePerm is set to true in config.yml
movecraft.commands - grants access to /pilot, /cruise, /release, /rotateleft, /rotateright, /craftreport
You can also control these granularly with:
movecraft.commands.release
movecraft.commands.pilot
movecraft.commands.rotateleft
movecraft.commands.rotateright
movecraft.commands.cruise
movecraft.commands.craftreport
Dependencies
Movecraft does not require any other plugin to function, however certain features require additional plugins:
WorldEdit (>6.0) - For repair system
Vault - For payment system
In addition, the following plugins are supported for compatibility:
Cannons - Cannons will move with a piloted craft
WorldGuard - Region protection
Most common permission plugins - Assign permissions to various craft features
Date sent: 2015/05/16 20:31:08
From reading that, in the bottom section it concludes that you do not need Forge to run it.
Date sent: 2015/06/02 12:06:35
YEEEES we NEEd that plugin. It would be great to travel around, exploring worlds.
-Dub
