Forum Index > Suggestions > Map Reset > Read the topic
Map Reset
futuretiger
Date sent: 2015/05/11 01:41:45
This is something the server deeply needs. Although there is a poll, the 'yes' variable is losing. Luigi, you need to simply announce a day, then reset the map that day. However, before this, we need to select a build team to build a new spawn. Or, you could use MCEdit to use this spawn (made by me):
http://www.mediafire.com/download/jb6hdsa58n5q8q6/SmallServerSpawn.zip
Date sent: 2015/05/11 03:48:09
The map is old and worn out. Most everywhere within about 6000 blocks of spawn is mined out and drained of anything remotely useful or claimed by inactive factions. A map reset would remove inactive factions, renew the land, and potentially cause less server lag.
ARNJ
Date sent: 2015/05/12 03:38:03
-11111
Date sent: 2015/05/12 14:09:51
Date sent: 2015/05/12 20:29:57
