Author | Message |
CaptainSpaceSheep |
Date sent: 2015/07/01 22:47:55
My minecraft suddenly crashes whenever I try to click multiplayer. I don't know what is going on, but if anyone could help, that'd be great. |
CaptainSpaceSheep |
Date sent: 2015/07/01 23:03:12
---- Minecraft Crash Report ----// Hey, that tickles! Hehehe! Time: 02/07/15 08:44 Description: Reading NBT data java.lang.ClassCastException: ce cannot be cast to cd at bs.d(SourceFile:116) at wm.c(SourceFile:123) at wm.a(SourceFile:70) at so.b(SourceFile:347) at sq.a(SourceFile:560) at jc.a(SourceFile:80) at mp.f(SourceFile:1053) at gu.a(SourceFile:152) at gu.a(SourceFile:52) at bjj.b(SourceFile:73) at net.minecraft.server.MinecraftServer.r(SourceFile:480) at net.minecraft.server.MinecraftServer.q(SourceFile:397) at bjg.q(SourceFile:122) at net.minecraft.server.MinecraftServer.run(SourceFile:331) at gp.run(SourceFile:573) A detailed walkthrough of the error, its code path and all known details is as follows: --------------------------------------------------------------------------------------- -- Corrupt NBT tag -- Details: Tag type found: STRING Tag type expected: SHORT Tag name: id Stacktrace: at bs.d(SourceFile:116) at wm.c(SourceFile:123) at wm.a(SourceFile:70) at so.b(SourceFile:347) at sq.a(SourceFile:560) at jc.a(SourceFile:80) -- Entity being loaded -- Details: Entity Type: null (jc) Entity ID: 1 Entity Name: Spyro0104 Entity's Exact location: -930.72, 59.99, 102.17 Entity's Block location: World: (-931,59,102), Chunk: (at 13,3,6 in -59,6; contains blocks -944,0,96 to -929,255,111), Region: (-2,0; contains chunks -64,0 to -33,31, blocks -1024,0,0 to -513,255,511) Entity's Momentum: 0.00, 0.00, 0.00 Stacktrace: at mp.f(SourceFile:1053) at gu.a(SourceFile:152) at gu.a(SourceFile:52) at bjj.b(SourceFile:73) at net.minecraft.server.MinecraftServer.r(SourceFile:480) at net.minecraft.server.MinecraftServer.q(SourceFile:397) at bjg.q(SourceFile:122) at net.minecraft.server.MinecraftServer.run(SourceFile:331) at gp.run(SourceFile:573) -- System Details -- Details: Minecraft Version: 1.5.2 Operating System: Windows 8 (x86) version 6.2 Java Version: 1.7.0_09, Oracle Corporation Java VM Version: Java HotSpot(TM) Client VM (mixed mode, sharing), Oracle Corporation Memory: 396623440 bytes (378 MB) / 518979584 bytes (494 MB) up to 518979584 bytes (494 MB) JVM Flags: 3 total; -Xms512m -Xmx512m -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump AABB Pool Size: 2 (112 bytes; 0 MB) allocated, 2 (112 bytes; 0 MB) used Suspicious classes: No suspicious classes found. IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0 Profiler Position: N/A (disabled) Vec3 Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used Player Count: 0 / 8; [] Type: Integrated Server (map_client.txt) Is Modded: Very likely; Jar signature invalidated There is the crash report, if that helps. |
Helperforever |
Date sent: 2015/07/02 00:01:08
Oh this is a karma crash , You get it for acting buddy with people in game and trying to get rid of them on the forums. Should go away when you apologize |
CaptainSpaceSheep |
Date sent: 2015/07/02 03:15:14
Oh, ok.Wait, then why does your minecraft work? |
CaptainSpaceSheep |
Date sent: 2015/07/02 03:29:08
Well, anyway, thats Win8 for you. I'll just stick with my mac. |
Larus_ |
Date sent: 2015/07/02 16:07:46
I recognize this error from a long time ago. I'm pretty sure and i've already said this on another topic you need to update your java or mc launcher. |
Larus_ |
Date sent: 2015/07/02 16:07:58
Larus_ |
Larus_ |
Date sent: 2015/07/02 16:08:35
Woops, my internet is playing tricks with me. Sorry |
CaptainSpaceSheep |
Date sent: 2015/07/02 20:18:24
I found this fix -Step 1 - Open Minecraft launcher and create a new profile to play on. Make in a very early version of minecraft. Launch the early version of Minecraft. Step 2 - Quit the game. Step 3 - Open up your usual playing profile and make it the earliest version of mc (1.8.7 at the time of this post). That is what I try with most bugs like those and it always works. :P |
Charity Carrington |
Date sent: 2023/06/22 07:41:49
Thanks for the help, I had the same error, your tips helped me |
